Le Deal du moment : -43%
-100€ Pack rééquipement Philips Hue ...
129.99 €
MARKA 1/28 EURO CUP 2024
MARKA 1/28 EURO CUP 2024 Empty MARKA 1/28 EURO CUP 2024
Message  Marco74 Mer 7 Fév 2024 - 22:41
MARKA 1/28 EURO CUP 2024 Img-2012
The MZCS crew is happy to welcome you for the first ever Marka 1/28 Euro Cup 2024, which will be held in Cluses (74300), France between 4 -7 April 2024.
The number of registrations are limited, and is on a first come first served basis (only validated once payment is received).
The RCP track size 18.5m x 8.5m
(Big tombola, Saturday evening, with prizes from our sponsors for all the drivers that are present for the Saturday evening dinner.
Race categories:
F1
Stock
Pro-Stock
Open 2wd
Open 4wd
(Maximum 3 categories per driver)
F1:
Chassis:
PNR 3.0F1, GL Racing GLF and G-Force Formula
Free chassis options, personal parts authorized subject to commission technical control (anything else is prohibited).
Engine:
Brushless motors of all brands up to 2500kv without sensor connected. Imposed ratio spur gear of 53 teeth and pinion gear of 12 teeth (with number of teeth clearly readable on spur & pinion gears). Preparation and changing of the rotor is prohibited.
Batteries:
2S Li-Po battery, maximum 8.40V.
Electronics:
Free
Body:
PN F1 Body #600821, GL F1 Body #GLF-S-001and G-Force Formula Body.
Front and rear Wing original is allowed.
Aftermarket production parts for PNR 3.0F1 or GLF or G-Force Formula are allowed.
Z-Performance front bumper (no ball bearing) and rear wing, as well as Chief Custom Front Wing CC-001 and CC002 are allowed.
Homemade parts, 3D print option parts and prototype parts are strictly forbidden.
Minimum authorized weight:
140g
Tires:
MARKA and PN RACING brand tires only.
Tire warmers are allowed. Tires may be cleaned with 70% alcohol solution only.
Traction compounds and tire cleaners are strictly prohibited.
Rims:
Front Wheel:
GL Racing GLF-S-003
PN Racing MR2088R0 & MR2088R0-19
Rear Wheel:
GL Racing GLF-S-004
PN Racing MR2088R14 & MR2088R14-19
STOCK:
Chassis:
Any 1/28 2WD chassis
Engine:
Lipo:  Brushless motors of all brands up to 2500kv without sensor connected. Imposed ratio spur gear of 53 teeth and pinion gear of 12 teeth (with number of teeth clearly readable on spur & pinion gears). Preparation and changing of the rotor is prohibited.
NiMh: all brands of brushed motors, minimum 70 turn with or without bearings
Brushless motors all brands up to 3500kv without sensor connected, ratio authorized any 64 pitch spur gear and pinion of 14 teeth max (RTR kits ratio in 0,5 module accepted, pinions 7t ,8t, 9t). Preparation and changing of the rotor is prohibited.
Batteries:
4 x AAA batteries type Nicd or NiMh
2S Li-Po battery, maximum 8.40V only for 2500kv motor
Electronics:
Free
Body:
With the exception of ‘Lola’/’Pan car’ style bodies, all bodies are authorized with a maximum wheelbase of 102mm, as long as they are in ABS material (Lexan bodies are prohibited).
Fins and rims must not exceed the contours of the body. The only holes tolerated are the ones for body posts and transponder IR led (everything else is prohibited). The removal of blades, spoilers (Audi, Aston Martin...) is tolerated. Lexan windows and/or roof allowed.
170 g
Tires:
Rims:
Maximum diameter: 20mm / front width: 8.5mm maximum /rear width: 11mm maximum.
The rims must not come out from the body. 3D printed rims allowed.
PRO STOCK:
Chassis:
Free chassis options, personal parts authorized subject to commission technical control (Anything else is prohibited)
Engine:
Lipo: Brushless motors of all brands up to 3500kv. Imposed ratio spur gear of 53 teeth and pinion gear of 10 teeth (with number of teeth clearly readable on spur & pinion gears). Preparation and changing of the rotor is prohibited.
NiMh: All brands of brushed motors up to minimum 50 turns, all brands brushless motors up to 5500kv. Authorized ratio spur gear of 53 teeth and pinion gear of 13 teeth (with number of teeth clearly readable on spur & pinion gears). Preparation and changing of the rotor is prohibited.
Batteries:
4 x AAA batteries type Nicd or Nimh
2S Li-Po battery, maximum 8.40V only for 3500 motor
Electronics:
Free
Body:
170g
Tires:
Rims:
Maximum diameter: 20mm / front width: 8.5mm maximum rear width: 11mm maximum.
OPEN 2WD:
Chassis:
Any 1/28 chassis
Engine:
Brushed class 130 & Brushless motor
Batteries:
Free
Electronics:
Free
Body:
Free
Free
Tires:
Rims:
Maximum diameter: 21mm / free width*
*the rims must not come out from the body.
OPEN 4WD:
Chassis:
Any 4WD 1/28 chassis
Engine:
Class 130 with brushed + Brushless motor
Batteries:
Free
Electronics:
Free
Body:
Free
Free
Tires:
Rims:
Race format:
The classification is done in ascending order based on the previous rounds’ finishing order. The duration of each heat is 7 minutes. Several heats will be run and the cumulation of the 3 best heats are retained for the calculation of the final result.
The day is made up as follows:
Round 1: Starting grid generated by the best time in free practice.
Round 2: Starting grid generated by the best result in round 1.
Round 3: Starting grid generated by the best round of the day.
Round 4: Starting grid generated by the best round of the day.
Round 5: Starting grid generated by the best round of the day.
Round 6 (or final): Starting grid generated by calculating the 3 best rounds of the day.
Marshalling: Drivers from the previous heat absolutely must be present for marshalling. Penalties will be handed to drivers missing and/or late for marshalling (warning given by the commission). Drivers will need to be mindful when marshalling.
If a driver cannot finish their heat (retirement, penalty, mechanical problem, etc.), the driver must remain on the podium (taking one step backwards) until the end of the heat, in order not to disturb the other drivers during the heat.
No repairs should be done around the track. Reparation of the cars may only be performed in the pits.
Only Robitronic type of transponders (easylap and others) is mandatory, owned by the driver and managed by them. The driver must ensure the proper functioning (clearing of IR Led, etc…) of their transponder. No complaints will be accepted in the event of a counting problem.
- The race will be managed with SnowRacing's – “Track My Lap” counting system.
- The race itself will take place on Friday through Sunday; Thursday will be dedicated to practice sessions only.
- Each category shall drive separately
- At the end of each heat all the pilots are classified according to the number of laps and time of the day.
- The position of the driver is done in ascending order based on all the heats of the previous rounds’ finishing order.
- The heats are automatically balanced.
- This method of classification has the advantage of making heats of very homogeneous level.
- At the end of the race, the 3 best rounds/time of each driver are accumulated.
- The end of day rankings are made by separate categories.
Race starting grid:
- The starts will be "staggered", with cars spread out over a few meters on the track, while trying however not to penalize the cars.
Important note:
- LiFe and LiPo batteries must be charged in fireproof bags, in the event of incidents only the owner will be held responsible, as a result of which the organization cannot be held responsible in the event of accidents.
Registration:
The registration fees for the MARKA Euro Cup are as follows:
€30 per person for the first category
€20 for each additional category (up to three total)
Meals:
Thursday lunch 12€: tomato mozzarella, lasagne, salad
Thursday dinner 12€: Vietnam salad, chicken and rise
Friday lunch 12€: raw vegetables, ‘tartiflette’ and salad
Friday dinner 12€: crusty pastry, beef stir-fry, pasta
Saturday lunch 12€: White Ham, rabbit stir-fry with potatoes
Saturday dinner 15€: smoked salmon, supreme poultry new potatoes
Sunday brunch 12€.
Race location:
Parvis de Esserts
36 Rue du Marcelly
74300 Cluses
Timetable:
--> Thursday
- Free practice from 08:00 a.m. until 07:30 p.m.
--> Friday
- Controlled free driving in the morning from 08:00 a.m. until 10:00 a.m.
- Beginning of the heats at 10:00 a.m. until 7:30 p.m.
--> Saturday
- Controlled free driving in the morning from 8:00 a.m. to 09:00 a.m.
- Beginning of the heats at 9:00 a.m. until 7:30 p.m.
--> Sunday
- Controlled free driving in the morning from 08:00 a.m. until 09:00 a.m.
- Beginning of the heats at 9:00 a.m. until 5:30 p.m.
(The above timetable are subject to change)
The bar:
Coffee, tea, drinks
Croissants, cakes and pastries
Registration for races and meals:
Registration for the race and meals are done via the online form:
Race registration shall open on Saturday 10 February 8pm onwards.(20h00)
Registration:
Link shall be available here on Saturday 10 February 2024 @ 8pm sharp! (20h00)  Very Happy
Inscription closed !
Https://www.paypal.com/paypalme/MinizClusesScionzier
PAYPAL payment between relatives/friends (payment is necessary to be registered) (any payment that is not between relatives will be refused as well as the registration)
A driver picture is also necessary to complete the registration and it has to be send at this mail address:
secretariat.mzcs@outlook.fr
You can view the registered drivers list by clicking on the following link:
Driver list
https://docs.google.com/spreadsheets/d/1YuC3X6SftUsxzKy1R1YwJ94YAF9bUJ1_LrBvCLUXy2s/edit?usp=sharing
AIRPORT:
Geneva International airport (Switzerland) 40km
Airport Annecy-Meythet 60km
Airport Lyon Saint Exupéry 175km
TRAIN STATION: the closest is CLUSES (74) 5 min by car
CAR:
Highway A40, exit 18 Scionzier-Cluses
From Paris 580km
From Lyon 190km
From Annecy 60km
From Geneva 45km
HOTEL LIST:
B&B HOTEL :
355, Av d'Italie 74300 CLUSES
28€ per person (at this price no cleaning services are provided during the stay)
Breakfast: 8.5€
Reservation only by mail : bb_4696@hotelbb.com
Tel. 08 92 23 31 18
Mob. +33 7 64 16 30 45
Pour la chambre d'hôtel c'est 56 € la chambre pour 1ou 2 personnes par nuit si il y a  2 personnes dans la chambre ça fera 28 € par personne mais si la personne est seule c'est 56 € .A partir de 3 personnes dans la même chambre c est 28 euros par personne toujours par nuit et il faut rajouter la taxe de séjour (A savoir que le prix normal est à partir de 72€)
Il faut préciser mzcs pour reserver.
For the hotel room it is 56euro per room per night for one or two persons (thus 28 euro per person if you are two). For three people in one room it is 28 euro per person, so if there are three people, the room cost is 84 euro/night. On top of this you need to add the nominal city tax which is per person per day. FYI the usual rate is 72 euro per night, therefore please indicate that MZCS when you are making the reservation.
HOTEL NATIONAL 2*:
6 place du cretet 74300 Cluses
Phone: +33 45098800
Room 1 or 2 pers: 75€
Room 3 pers (2 beds): 95€
Room for 4 people (3 beds): €105
Breakfast: 9€
HOTEL 4C:
301 Boulevard du Chevran 74300 Cluses
Phone: +33 450980100
Single room: 82€
Double room (double bed): €89
Twin room (2 single beds): €92
Buffet breakfast: 11€
The room rate is for the 1st night from the 2nd night 60€ (excluding cleaning)
HOTEL DU FAUCIGNY: (4km from Cluses)
170 rue Cesar Vuarchex 74950 Scionzier
Phone: +33 450981671
Room for 1 or 2 people (1 bed): €91
Double room (2 beds): €110
Room 3 or 4 people (3 beds): 120€
Breakfast 12€
The MZCS crew
MARKA 1/28 EURO CUP 2024 Snow_r10
MARKA 1/28 EURO CUP 2024 Track_10
MARKA 1/28 EURO CUP 2024 Logo_o10
Marco74
Marco74
MARKA 1/28 EURO CUP 2024 Empty Re: MARKA 1/28 EURO CUP 2024
Message  snowboarder38 Sam 10 Fév 2024 - 18:39
Tic Tac Tic Tac on vous attend nombreux ce soir à 20H
Pas plus qu'a fond  Wink  MARKA 1/28 EURO CUP 2024 Snow_a11
Message  pic94 Sam 10 Fév 2024 - 20:11
Bonjour , est il possible de réserver des repas pour un accompagnateur ?
pic94
pic94
Message  Marco74 Sam 10 Fév 2024 - 22:40
Oui sans problème.
Elle veut tous les repas ?
Merci je fais la correction demain soir.
Marco74
Marco74
Message  Marco74 Dim 11 Fév 2024 - 17:55
Problème avec l hôtel BB.
Il faut appeler, et dire MZCS pour pouvoir avoir la réduction à 28 euros par personnes à partir de 2 personnes par chambre. Une personne par chambre seule 56 euros.
Hi,
Yes indeed, it is 28 euros under conditions.
You must call the hotel directly on the telephone and say MZCS when registering.
A single room is 56 euros instead of 72 euros.
A room for 2 is 28 per person.
Same for one of 3 people.
I will correct it very quickly on the post.
Marco74
Marco74
Lolo rc aime ce message
Message  fred2621 Ven 1 Mar 2024 - 12:03
Je vois que ma ligne n est pas en vert dans le fichier, j ai bien envoyé ma photo par email, il y a t il autre chose qui manque pour valider mon inscription ?
fred2621
fred2621
Message  Marco74 Ven 1 Mar 2024 - 12:16
Salut fred, je te mp.
Marco74
Marco74
fred2621 aime ce message
Message  fino Jeu 11 Avr 2024 - 19:45
+90 pilotes
4 jours de courses
8 finales
18 séries à envoyer à chaque finale
Stock, ProStock, F1, Open 2wd, Open 4wd
Un très haut niveau de pilotage
Merci pour l'organisation globale, c'était un excellent week-end sur tous les aspects (timing, roulage, buvette, tombola, bar, etc.)
MARKA 1/28 EURO CUP 2024 Fb_img23
MARKA 1/28 EURO CUP 2024 Fb_img22
fino
fino
http://www.miniz59.fr
