35 €
Variateur Programmable 1/27 Team Powers
Variateur Programmable 1/27 Team Powers Empty Variateur Programmable 1/27 Team Powers
Message  prp Mer 19 Avr 2017 - 21:51
Team Powers M-Radon ESC & MBX sensored BL motor
Variateur Programmable 1/27 Team Powers PowersMRadon-1
Team Powers have released first information on their forthcoming M-Radon sensored brushless speed controller and sensored MBX brushless motor. Aimed towards the use in 1/27th mini-size cars, 1/10th motorcycles and other applications, the speed controller makes use of hardware and software ideas taken over from the Radon V2 1/10th speed controller to create a powerful yet widely adjustable ESC that allows for adjustable drive and brake frequencies, power band control and even data recording functions. The controller is adjustable using a simple LED programming card or an optional PC interface and it is usable with 2S LiPo packs and up to 10,000kv brushless motors. As for the motor, the MBX is of a sensored design for improved low-RPM start up without cogging issues, it measures 16x27mm and is available in a 7200kv or 8400kv variant.
M-Radon speed controller specifications:
– Battery input voltage: 2S LiPo
– BEC: 6V/1.5A
– 1/27 motor limit: <10000kv
– Max Ampere draw: ~20A per phase
– Size: 21x24x10mm
– Weight: 10g w/o wires
MBX brushless motor specifications:
– Sensor type
– Dimensions: 16x27mm
– Shaft diameter: 2mm
– Weight: 18.5g
– Available KV: 7200KV, 8400KV
Variateur Programmable 1/27 Team Powers PowersMBX-1
Source: Team Powers [team-powers.com]
prp
prp
Variateur Programmable 1/27 Team Powers Empty Re: Variateur Programmable 1/27 Team Powers
Message  morphehus Jeu 20 Avr 2017 - 8:14
Il a l'air intéressant, dommage que le BEC soit à 6V.
Sur un montage avec le servo board de chez PNracing cela va poser problème et il faudra ajouter un régulateur de tension pour l'abaisser à 5V.
Mais cela reste intéressant quand même.
morphehus
morphehus
Message  prp Ven 21 Avr 2017 - 8:11
J'ai transmis ton info au magasin qui importe Team Powers en France, il va se renseigner.
prp
prp
Message  NICOLAS.T Ven 21 Avr 2017 - 10:53
Cela devient très intéressant..... Very Happy
NICOLAS.T
NICOLAS.T
Message  prp Jeu 17 Aoû 2017 - 22:50
Le combo est disponible chez l'importateur Select Import, c'est très joli en vrai.
prp
prp
Message  thib Ven 18 Aoû 2017 - 10:15
Cool!! Le ticket est à combien??
Variateur Programmable 1/27 Team Powers Broche10
